Pc Ontv
Aug 31, 2009
123
Hi
I've just rigged up a spare PC onto the TV in the lounge so we can do a bit of karaoke and watch a bit of you tube on a big screen.
Thing is, every now and again it comes up no signal and then the picture on the screen reappears.
Am I doing something wrong or is the normal when you use a 36inch TV as a PC screen
is it sync'd properly?  ie, frame rate etc,
are you using windoze? if so I have NO idea how to do it,
but I can watch my PC or laptop perfectly fine on my living room tv.
sorry, Im on Ubuntu and it syncs spot on by itself on the PC,
occassionally on the lappie I have to go into screen settings and change the 2nd screen[tv] to a different setting,
as its on 2 screens[laptop & tv] I have to change tv from mirrored as its a different resolution to the lappie screen,
buts thats the only issue,
it never blacks out,
are you using HDMI or VGA ?
could be a dodgy lead if its an interrmittent thing,  :C
ive come from monitor out to monitor in on the TV. I'm using a multi pin monitor lead
