I have been meaning to post these pics of a lead sheathed service cable for a while now, circa 1965 but with a newer earth connection. This one was TNS. These pics are the end section that would have been connected to the service cut out (head).
1st pic is a overview. The service fuse was connected to the right hand top cable & the neutral to the left hand top cable. Bottom would have gone into the ground.
Next pic is a view of the cut off end showing the concentric construction. Cable appears to be 25mm which is unusually large for a domestic as this service had 2 X 100A service fuses connected
This pic is of the cut off end that i stripped back to show the lead sheath and the oiled paper insulation
Last pic is of a constant spring earth clip onto the lead sheath that replaced the older soldered joins.
A TNCS cable end would be the same except no lead sheath. The earth would be connected to the neutral in the service head.
