- Mar 28, 2008
- 13,619
- 296
I had to quote for some work the other day at a house that had a PIR done when they moved in.. (12mnth + ago)...
The PIR had some observations that needed improvement, which the customer showed me, I noticed on the front page......
Extent of installation covered :
said "Full installation"
Agreed Limitation to Insp & Test :
said "None"
which in reality... doesn't happed... {unless blank cheque and open ended time scale}
You cannot test the WHOLE installation with NO limitations and this could actually leave some serious liabilities with the contractor doing the PIR!!
For a Domestic property I have a standard description to put in this box..
[Agreed Limitation on Inspection and Testing.]
and covers your backside in case there are nasties under the floorboards..
such as sellotaped joints...
said "None"
universal.. covers just about every domestic property!No lifting of floorboards or exposing concealed cables or boxes. Sample of sockets, switches & light fittings opened & inspected. Some fittings unable to open due to risk of damage to decoration.
