Some farmers diy electrikery
The cu in the barn supplied by a 27 meter run of 6mm T/E clipped direct to outside of barns & stables + 9 meters on catinary.
http://i83.photobucket.com/albums/j293/gazjothomas/electrical001.jpg
The inside of the barn cu....nice mix of ocpd & no rcd apart from the 100mA at the service head TP & N supply
http://i83.photobucket.com/albums/j293/gazjothomas/electrical002.jpg
JB for the lighting
http://i83.photobucket.com/albums/j293/gazjothomas/electrical003.jpg
Flex to outside bulkhead lighting
http://i83.photobucket.com/albums/j293/gazjothomas/electrical004.jpg
Light pendant in the washroom + twin to the doorbell tranny, nice use of ceramic wirenut.
http://i83.photobucket.com/albums/j293/gazjothomas/protec006.jpg
The incomming supply + smashed 400v 32a outlet. The small 45amp rated cu with 40amp breaker is the submain to the barn, supply to this cu is 6mm straight off the 3P&N 60amp switch fuse chamber to the left.
http://i83.photobucket.com/albums/j293/gazjothomas/electrical005.jpg
No socket or isolation switch for a pillar drill, just this nice chocblock connection...... at least it's got tape on it.
http://i83.photobucket.com/albums/j293/gazjothomas/electrical006.jpg
JB for the lighting
