Although Karlos stated bonding, it appears he is referring to the Main earth which would still be needed for the 17th edition, although maybe not in this circumstance.you only bond metal pipes that could have an earth potential (in direct contact with earth). why not go by 17th edition an install an RCD on the bathroom circuits then bonding is not an issuecraig
NO such thing as a MAIN EARTH. (or do you have a secondary one also?)Although Karlos stated bonding, it appears he is referring to the Main earth which would still be needed for the 17th edition, although maybe not in this circumstance.
until the 1st of July................All I will tell you is this....... Bond, bond, bond and more bond, then bond some more.You can never bond enough, cover every aspect you can think of, then bond some more.
Am I getting this accross yet?
Register today and take advantage of membership benefits.
