Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Intruder, Fire, CCTV, Emg Light, Access Control
Please Help Identify This Alarm, It's Beeping Incessantly!
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="SPECIAL LOCATION" data-source="post: 333733" data-attributes="member: 250"><p>The external bell box has its own battery....</p><p></p><p>that is the bit that is making the sounder operate.. </p><p></p><p>There will be another control panel somewhere..</p><p></p><p>(in cupboard.. under stairs.. in garage.. by fuse box etc.... etc...)</p><p></p><p>With another battery...</p><p></p><p>That battery will be a rechargeable lead acid battery that should have been replace approx every 5 years...</p><p></p><p>If its not been replaced since the 90's then its well and truly knacked IMHO...</p><p></p><p>If the battery is that old it can cause the panel to do unpredictable things... </p><p></p><p>my only advice would be....</p><p></p><p>If it is the landlord who wants it kept and it is on his property..</p><p></p><p>He should be getting it fixed or removed...</p><p></p><p>Not up to you to get involved!!</p></blockquote><p></p>
[QUOTE="SPECIAL LOCATION, post: 333733, member: 250"] The external bell box has its own battery.... that is the bit that is making the sounder operate.. There will be another control panel somewhere.. (in cupboard.. under stairs.. in garage.. by fuse box etc.... etc...) With another battery... That battery will be a rechargeable lead acid battery that should have been replace approx every 5 years... If its not been replaced since the 90's then its well and truly knacked IMHO... If the battery is that old it can cause the panel to do unpredictable things... my only advice would be.... If it is the landlord who wants it kept and it is on his property.. He should be getting it fixed or removed... Not up to you to get involved!! [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
