Hi guys could you have a look over the spec below & seee what you come up with price wise, i quoted & won this job a few months ago & recently had a site meeting to check requirements where the client added a load of extras such as loads of 2way & int lighting & supplies for renewables such as solar pv & ASHP. The job is a large extension to a 2 bed cottage with a lot of changes to the existing wiring & the client wasnt happy with my estimate of 2.5k for the extras so i wanted a couple of second opinions if possible.
I have recently had a new baby & have become a bibt stressed over this situation.
Apologies for the long post & if its in the wrong area of the forum. headbang
Regards
Gram
22 No. Double socket outlet
7 No. Supply for built-in appliance
5 No. Pendant light point via 1 way switch
1 No. Pendant light point via 2 way switch
6 No. Batten light point via 1 way switch
4 No. Smoke/Heat detector
3 No. Shaver Points
3 No. Humidity extractor fan & isolator switch
3 No. Tv Point
4 No. FR Spots via intermediate switch
9 No. FR Spots via 2 way switch
4 No. External PIR wall light (wiring only) via 2 way switch
1 No. External PIR wall light (wiring only) via intermediate switch
1 No. Cooker control & outlet 1
10 No. LED Soffit down lights
3 No. 5 Amp sockets via 1 way switch position
1 No. double external socket in garden (40mtr 4mm SWA, duct in place)
1 No. double external socket adjacent to plant room
3 No. weatherproof light fittings under decking storage area
1 No. 15 way dual RCD Board
Bonding to gas & water services
1 No. Metal clad 14 way consumer unit in plant room to supply ASHP & UFH & Solar PV
1 No. 20mtr 4mm SWA supply for ASHP located in garden with external isolator
1 No. Plant room isolator for ASHP controller.
1 No. Double Pole contactor for 2.5kw HW Immersion
1 No. Double Pole contactor for 2kw Buffer Immersion
2 No. Isolator for UFH Manifold (1 on Ground Floor, 1 on 1st Floor)
Regards
Gram
3 No. Shaver Points
3 No. Tv Point
