- Nov 28, 2009
- 14,765
- 955
I'm re fitting a new bathroom in a flat. Trying to use as much of the existing plumbing as possible, and I have encountered a problem with the toilet fill valve.
The old toilet was filled with water from the cold water header tank, and as that header tank is on a stand above the hot water cylinder in the adjacent airing cupboard, the water pressure is extremely low, about 5ft of head.
The old toilet had a conventional float valve. The new one has a bottom entry Torbeck valve, similar to Screwfix part number 75136
The problem is firstly the fill is extremely slow (much slower than the old toilets fill valve, which was already pretty slow), but when full it does not shut off, in spite of the float floating up as far as it can.
Am I right in saying these types of fill valve won't work on such low water pressure? I have removed the flow restrictor which the instructions say to do for water pressure below 1 bar.
If this is the wrong type of valve for this application, what can I use instead. I really can't see that there is enough room in the small cistern for a conventional float valve.
The only other (unquestionably better) option would be to re plumb to get mains water to the WC, but everything is boxed in and it would be a major job to gain access to feed a new pipe, so that really is a last resort. I would prefer to find an alternative fill valve that will work on this very low pressure.
