I am looking to configure pulsed outputs on an EDMI meter and was hoping someone could explain the difference between using a Primary / Secondary pulse constant?
I assume it has something to do with the CT/VT ratios but can't quite get my head around how they are different as in my head even if the meter is looking at Secondary current to determine the KWh and in turn when to pulse it must have an idea of the primary to calculate when a KWh has been used and when it should output a pulse.
