ian932
Here is one for Mr JL, we are currently building our own place and I'm looking to run a 22mm hot water loop.
The layout is:- at one end of the building is a HW cylinder in a Grd Flr Utility room with an ensuite above it and then 16m down the other end of the building is a Grd Flr Bathroom with another ensuite above this.
With me so far? right I'm going to run 3 legs of 22mm in the Grd Flr ceiling space from one end to the other, this is a 16m staright run, 2 legs will be the HW loop and the other leg will be the cold feed.
The question is, I want to run JG speedfit for the 16m legs then run copper at either end to the various tap and shower points, I'm concerned that once I fit the insert to the JG pipe the bore is reduced to about 17mm, will this give me a problem with the flow/presure to 3 bathrooms?
Phew!! I think I got there in the end. By the way if it helps, the mains presure here is mega, I've not tested it but i'd guess its well over 3.5 bar. Half a turn on the old garden tap and the hose is leaping around trying to whip ya eye out !!
