Sorry pal, not enough info for me to start calling peeps names , I will leave it to you:consolingIts in the DTI guide hereDepending on circumstances i personally disagree with it if the installation is designed and installed correctly with the correct kit
But thats for another debate, lets wait for Ivor :slap
Basically by doing so as SW states you now have a massive lightning attraction device on your roof....
Extraneous-conductive-part - A conductive part liable to introduce a potential, generally Earth potential, and not forming part of the electrical installation. .
On the d.c. side of the PV installation the designer will have usually already selected double or reinforced insulation as the protective measure
and therefore the component parts of the installation will be isolated from earth, the frame of the array has to be assessed as to whether it is
likely to introduce a potential into the installation. This aim of this assessment is to find out if the frame has any direct contact with ground that would make it introduce a potential.
The details on carrying out these tests are best given in the IET
Thanks - that second document refers to latest "Guide to the Installation of Photovoltaic Systems" which I found a link to on the same site.Canoeboy said:See here for full list
http://www.microgenerationcertification.org/mcs-standards/installer-standards
This is the latest pv one
http://www.microgenerationcertification.org/images/PV%20Book%20ELECTRONIC.pdf
Its all in there
