classacitizen@btinternet.
I've got an outbuilding with secondary consumer unit that runs back to the cut out and splits there. i.e one set of tails goes to the main house consumer unit and one set of tails goes to the outbuilding consumer unit. (appropriate sized barrel fuse there rated to the cable)
Can i connect a hybrid pv system with battery storage to the garage cu so that it will power the entire system i.e the house as well,
will this work efficiently or does the system have to be wired into the main consumer unit?
