quick help with 206 practical
kiwiNCFC
Apr 19, 2009
155
Hi guys, Got my practical soon. Got to do a radial circuit in pvc conduit and 2 way lighting circuit with 2 lamps in steel conduit. Also got to do S.W.A from an isolator to the consumer unit. Just doing the paperwork now and doing the materials list and tools lists. Hopefully this will help others as well as me. This is what i have done so far:
Tools/ppe:
Vice (on hilmoor)
Metal Spring
Cloth (for rubbing pvc conduit)
reamer
pvc conduit cutters
kneepad
half round file
pozi screwdriver vde
large vde flat head screwdriver
small vde flat head screwdriver
vde side cutters
vde wire strippers
spirit level
5m tape measure
junior hacksaw
combi drill
drill bit
safety boots
goggles
vde pliers
medium hacksaw
set square
pen
holesaw
insulated gloves
Materials:
4x twin 13a sw sockets
2x 2 way switch
2x luminaires
2x ceiling roses
1.5M of PVC 25mm conduit
3M of steel 25mm conduit
1x steel terminal box
1x steel angled box
1M of steel trunking
1x consumer unit
1x isolator
10x Steel conduit couplers
8x plastic conduit couplers
2x pvc shrouds for swa
10x brass bushes
8x plastic bushes
6x pvc conduit clips
10x saddle baseplates
10x saddle clips
5M of 1.5mm brown pvc conduit cable 6491x
5m of g+y earth sleeving 3mm
1x 6a MCB type b
16x m3.5 electrical screws
3M of 1.5mm blue pvc conduit cable 6491x
3M of 2.5mm brown conduit cable
3M of 2.5mm blue conduit cable
swa:
2x swa nuts
2x earth tags
2x swa nozzle
2x swa collar
2x collar nut
2x swa nut with rubber seal
Any one else got anything i can add, will talk to my tutor tomorrow before i hand it in, still needs lots of work.
You have 5 metres of earth sleeving but no earth cable?!
Can you get VDE wire strippers?
Do you need to specify size of drill bit? Is it HSS/masonary? Wall plugs?
Thanks! Didnt think of the cpc! Yeh i think you can get vde strippers they are orange and yellow at my college just like the screwdrivers
Most hand held tool companies do VDE strippers Apache :) AndyGuinness
You are, of course, correct. I was looking at some automatic wire strippers and I never saw them in a VDE varient.
These type are readily available
I di mean to go back and edit my post ;)
what about ur insulation resistance tester, low ohm meter, earth loop impedance tester, RCD tester.....
OSG, connector block, general fixing screws, washes.... etc...
