- Joined
- Jun 21, 2008
- Messages
- 17,024
- Reaction score
- 47
Plan is to collect rainwater in 6 X 1000l IBC containers, connected together (outside). A pipe then runs ~12m underground and then needs to rise 3m to fill a header tank.
The header tank is to feed a pressure washer - that can run off a ground level water-butt.
What is the best way of moving the water? Some kind of pump controlled by a float switch - I assume?
Does pump want to be at ground level or up next to the header tank (my preferred location).
Looking for a suitable pump and switch - also interested in any thoughts or suggestions
Cheers
http://www.ebay.co.uk/itm/Inline-Water-Pump-Centrifugal-1-inch-BSP-Cast-Iron-IBC-Water-Pump-IBC-Fitting-/281134830013?hash=item4174f111bd:g:H9gAAOSwd4tUKoTu
Something like this?
Cheers
