Mike.J
- Jan 4, 2022
- 226
- 74
Thanks for the feedback Dave, tell me how do they get two sensing coils inside a single module RCBO? On the single module ones I have taken apart the sensing coil is too big to be accommodated on both the line and neutral in a single module, I have also found that two in and two out and no fly lead is no indication of 3mm two pole switching, the line is through the sensing coil, but the neutral is physically attached to the line contacts (electrically separated) and does not have it's own sensor, therefore I surmised the neutral will not trip on overload only on an earth fault, or the other way around?
