Hi, I am an electrical contractor who works mainly in breweries. My friend rang me to say his Rcd kept tripping and it wouldn't stay on when he turned it back on.
I went round and he had already switched the 3 circuits off from the Rcd and unplugged all the appliances from both ring circuits. When I arrived the rcd with no load on was working correctly i.e the test button operated correctly. But with any of the 3 circuits turned on it would immediately trip.
I disconnected the L and N from the board for both the ring mains and found that I was getting continuity between the L and N from the downstairs ring. So we took all the socked and spur faces off everywhere downstairs. I then returned to the board and there was no longer continuity there so I put it down to that. But when I connected the ring back in the rcd would still trip.
He's had the house from new for 11 years and not had any problems before until now and said he hadn't done any work or anything out of the ordinary for this to happen.
I tried replacing the rcd but it didn't work. As I rarely work domestically I was wondering if anyone had any ideas.
The 3 rcd protected circuits are the upstairs and downstairs ring mains and an immersion heater.
Cheers
Cheers
