Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrician Talk Forum
Recommendations for boiler timer controller?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ProDave" data-source="post: 496015" data-attributes="member: 6969"><p>If he is regularly using the boost switch, are you sure the bottom heater is working? If that has failed then the boost switch will be his only option.</p><p></p><p>Otherwise as noted some education needed. By default the bottom heater is already on a timer, for 7 hours at night on the cheap rate.</p></blockquote><p></p>
[QUOTE="ProDave, post: 496015, member: 6969"] If he is regularly using the boost switch, are you sure the bottom heater is working? If that has failed then the boost switch will be his only option. Otherwise as noted some education needed. By default the bottom heater is already on a timer, for 7 hours at night on the cheap rate. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
