ian932
What reference method would you apply for derating cables fitted in the following constructions.
Starting from the outside inwards -concrete block, 100mm cavity, 60mm kingspan fixed to inner concrete block leaving a 40mm air gap in the cavity, cable fixed to inner block with metal capping, 42.5mm kingspan/plasterboard on dabs.
Next one is the roof starting from the outside again - tile, paper, 50mm air gap, 160 kingspan between rafters, 15mm void with cable in that, 42.5mm kingspan/plasterboard (rafters are 225mm)
I reckon first one could be classed A I think 103 would be OTT as the cable will discharge heat through the block. The Second one looks like it may be 103.
What do you guys think?
