Removing tiles
Theorysparky
Domestic Electrician
Feb 18, 2008
4,233
Hi guys
Been asked to add two double sockets in a diy kitchen. This is part of a cu change, new garage supply etc so i am expecting some horrors !!!!
Anyway a 2 1/2 metre worktop has no sockets but is tiled thankfully in cheap white type. I need to remove the centre row to run the cable.
What is the best way to do it without cracking the ones above and below
Cheers
ABC Technical
May 1, 2008
885
This is how I do it.
Step1. Remove the grout from all of the edges of the tiles that you wish to remove.
Step2. Drill some holes in the tiles to be removed (Ceramic bit)
Step3. Use a hammer and cold chisel to cut the tile between the holes you have drilled, chop out the center protion of the tiles. (taking care not to damage the ones you want left intact)
Step4. working towards the edge of the tiles to be removed, remove all the edges of the tiles taking care again not to damage the ones you want left intact.
Then when you have finsihed the install it should be an easy job to replace the tiles.
Somebody may have a different/better way than this, but it works fine for me.
Hope its useful to you.
Theorysparky
Feb 18, 2008
4,233
Sounds a good way to go about it
might take longer than i thought though
Cheers for that
ABC Technical
May 1, 2008
885
Yes it is labourious, but at least you may only hav to replace the ones you remove instead of a load you accidently break.
You are most welcome Theo.
extension15
Distinguished Member
Feb 13, 2008
1,659
This is how I do it.Step1. Remove the grout from all of the edges of the tiles that you wish to remove.
And charge the customer accordingly..
B)
extension15
Feb 13, 2008
1,659
But of course. B)
I've cleared the way so to speak, when having to remove tiles, it's not that hard, just a bit of due care and attention..
:_|
Mar 28, 2008
13,618
296
Evnin Theory! :D
Re ABC's first suggestion..
Definitely need to remove all of the grout around the tiles...
& I assume we are all talking some sort of a proper grout removal tool..
serrated blade with nice grippy handle...
not a screwdriver & knife:_|
available from B&Q or similar establishment! ]:)
Once all of the grout is shifted..
before drilling & cutting I would explore how well they are actually stuck to the wall?
I keep an old wide blade wood chisel (1 1/2" or 2")...
which can be gently prised behind one of the tiles...
I have found in the past sometimes they actually pop off the wall intact without needing to break the tile.
I have also heard... (but never tried)...
That a wallpaper steam stripper will loosen or soften tile adhesive allowing tiles to be removed intact?
Has the customer actually got spare tiles or can you get an equivalent match?
in which case just do the quickest remove operation! :D
I have previously actually cut up the plaster behind tiles on the wall from below worktop level...
customer had nice tiles.. didn't want to change.. had no spares..
Cut hole in wall for metal back box... sink for deep box... make exploratory hole below worktop level...
clear plaster back to wall.... drill up with long narrow drill bit
(the sort that you can bend and flex slightly as you drill it)...
use battery drill ease up through plaster aiming for the sunk box location you just cut.
Takes time.. but can be done...
Customer chuffed cuz there nice tiles still intact! :D
SL:)
Mar 7, 2008
9,994
In the office again.
Theo:
Spent quite a few years working with a bathroom & kitchen firm. Lot of the work involved removing old tiles.
Q1...What is the wall construction behind them. This makes a MASSIVE difference in the way to remove them!
Q2... What is the approx. size of the tile in question?
However - irrespective of these; the first stage is indeed to remove the grout. A stanley knife is a very good tool for this; as it does not stress the tiles. Just be aware that the body of the stanley can leave marks on the tiles, if you let it drag across them!
Give me the answers to Qs above, and we`ll discuss further. n.b. dependant on answers, a crowbar (serious) can be very useful.
Theorysparky
Feb 18, 2008
4,233
Theo:Spent quite a few years working with a bathroom & kitchen firm. Lot of the work involved removing old tiles.
Q1
brick to one corner then onto stud wall where the sockets will go
Q2
they are the 150mm plain white cheapo tiles so easy to get replacements and the customer is happy to lose them.
ABC Technical
May 1, 2008
885
Evnin Theory! :D Re ABC's first suggestion..
Yes, they are cheap as chips also
I will try to remember this method for when I do my bathroom, might work?
:D
Theorysparky
Feb 18, 2008
4,233
I have in an old bathroom just tiled over tiles
it was easier :D
Mar 7, 2008
9,994
Q1brick to one corner then onto stud wall where the sockets will go
Q2
Ok m8:
Cheapo tiles aren`t coming off in one piece generally. On the section against brick, once the grout is away from the tiles to remove, use a bolster, and lumpa (with eye protection) to get behind the biscuit of the tile, and lever/prise/smash from wall.
As for the plasterboard; I would cut the section of plasterboard out (plasterboard saw would be the tool of choice), and remove whole section, plasterboard & tiles. Cut new piece of plasterboard in afterwards m8.
Clear ( as the proverbial?)
KME
Mar 28, 2008
13,618
296
Cheers for thatlooks like im gonna have some fun ]:) ] :)
Spose it does all hinge on...
hew well the tiles were stuck in the first place? ?:|
I have been to a couple of jobs where the tiles could almost be pulled off with your bare hands......
or certainly with a basic wall paper scrapping knife.
they were installed with a very economical view to adhesive!!
So you never know m8... it may be an absolute doddle! :D :D
send back some pictures of how you find them once you've got them removed? :)
Mar 28, 2008
13,618
296
:D
I would just say in my defence...
in case this method doesn't work.....
that I was told it by my younger sister...
and she heard it from a friend!!!
not sure whether you would need to shift the grout first to let steam penetrate behind the tiles????? ?:| ? :| :)
who knows??? any offers.....
answers on a post card please! :^O
steptoe
Feb 13, 2008
24,337
117
Gtr Manchester
if it does work,
surely you could end up with a whole wall full of tiles no longer being full of tiles, if you get my drift.
I dont think the steam would be too fussy about which tiles it loosens. :eek:
Mar 7, 2008
9,994
Well, a grouted tiled wall is SUPPOSED to be waterproof. Yes, the grout would still have to come out.
I`d never heard this one b4; and tend to think as steppie here - the tiles don`t know which are supposed to come off!!!
But let`s hear more about the sister`s friend! Who is she?
steptoe
Feb 13, 2008
24,337
117
Gtr Manchester
or the sister, how young is she really????? ]:) :p :eek: :p] :) :p
