Robojin
- Jan 22, 2009
- 1,122
- 0
On a recent Home AV install, the customer wanted HDMI over CAT6 distributed from a media room, As a fall back and just in case of some technical issue with CAT6 we installed an HDMI cable local to the TV
Suffice to say during the TV install the HDMI head got damaged (outer screen broke from moulding) and the cable was SNAFU
Just to make life interesting, the technical issue did appear (AppleTV does not HDCP sync with Samsung over the baluns), so was left with the problem of how to solve, routing a new cable is not an option due to the location.
Up until this point I'd assumed that dressing HDMI cables was not an option, until that is, you buy these
http://www.toby.co.uk/content/catalogue/products.aspx?series=51D-019P-30N1-1A21
and instructions here
http://www.digitalmatrixusa.com/hdkit/pdf/diy_Instruction.pdf
If you fancy close pin soldering Toby have a solder version too
So now if you need to run HDMI through joists etc, rather than drill 22mm holes you could get away with 10-12mm
