Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Replacement Defrost Thermostat - Different Colour Wires
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Geoff1946" data-source="post: 502311" data-attributes="member: 28452"><p>With two connections I consider it's unlikely to be anything more than a pair of switch contacts, but at best part of £50 a shot I understand your reluctance to gamble.</p><p></p><p>What I can't make sense of is that the two wires from the device appear to go to the two right hand terminals, BUT the other wire from each of those seems to go to the third terminal which would short out the device!</p><p></p><p>Perhaps that's an illusion in the photo?</p><p></p><p>Can you not get technical advice from the spares supplier you bought it off?</p><p></p><p>Give it a bit longer and someone else may be along here with a more enlightening answer. It's not however a group which deals much with appliance repair so you may be wise to search elsewhere.</p></blockquote><p></p>
[QUOTE="Geoff1946, post: 502311, member: 28452"] With two connections I consider it's unlikely to be anything more than a pair of switch contacts, but at best part of £50 a shot I understand your reluctance to gamble. What I can't make sense of is that the two wires from the device appear to go to the two right hand terminals, BUT the other wire from each of those seems to go to the third terminal which would short out the device! Perhaps that's an illusion in the photo? Can you not get technical advice from the spares supplier you bought it off? Give it a bit longer and someone else may be along here with a more enlightening answer. It's not however a group which deals much with appliance repair so you may be wise to search elsewhere. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
