Hello,
I wanted to replace a Columbus Vacuum time lag switch (https://new.abb.com/low-voltage/products/lighting-emergency-lighting/lighting/elkay/timers-switches/columbus-pneumatic-timer) which has stopped working with an Elkay Standard Push button (https://new.abb.com/low-voltage/products/lighting-emergency-lighting/lighting/elkay/timers-switches/standard-push-button-timer)
The wiring we have seems a bit complex ...
In the current one there are a
COM / NC / NO.
There is 1 red wire in COM / 1 Red wire and 1 yellow wire in NC / 1 Blue and 1 Black in NO.
The Standard push button has instead of a COM / NC / NO the terminals are L / N / SL.
Can I replace the vacuum with the standard?
How do COM / NC / NO map vs. L / N / SL?
Do I put the 2 Blue and Black which I suppose are neutral into N? There are then the 2 red and 1 yellow ... one that goes in COM and the other 2 go in NC... Not sure which would go in which.
COM / NC / NO.
