Evening fellas can any of you kind hearted gentlemen help with the question below ??,
A cable carries a current of 65A with a 13v drop. what must be the resistance of a cable wich,when connected in parrallel with the first cable, will reduce the voltage drop to 5v.
As before fellas if you have the answer and the means I would be grateful.
regards Iain
regards Iain
