Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Scutch chisels
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Lurch" data-source="post: 119529" data-attributes="member: 6967"><p>As long as it's mostly in it will be held in by the fact you are constantly hitting it into position in use. Mine does occasionally move slightly if you use the edge of the comb, just a couple of whacks with the comb flat sorts that out. No need to demolish the garden wedging it in before putting it in the tool box!</p></blockquote><p></p>
[QUOTE="Lurch, post: 119529, member: 6967"] As long as it's mostly in it will be held in by the fact you are constantly hitting it into position in use. Mine does occasionally move slightly if you use the edge of the comb, just a couple of whacks with the comb flat sorts that out. No need to demolish the garden wedging it in before putting it in the tool box! [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
Scutch chisels
