freedomrun
- Feb 3, 2010
- 65
- 0
Domestic PME, 2 lighting cct's (over 2 floors in semi) all circuits other than the lighting cct's are RCD protected to 30mA on a split board CU. Going to install an extractor in the bathroom, just outside the bathroom is a hall light operated by a two way switch that is connected to the lower floor lighting cct, i was thinking about moving the upper lighting circuit that the bathroom lighting is on - to the RCD protected side of the board rather than increase the cost with an RCBO and leave the lower floor lighting with the upper hall light on it where it is (not RCD protected), so if the RCD does trip, the upper hall light will still be working and all lighting on the lower floor. Any deviation from the regs in doing this, any advice please? thanks.
