Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrician Talk Forum
Selectable power socket?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="phil d" data-source="post: 481987" data-attributes="member: 27126"><p>So from yesterdays initial idea you now want a master emergency stop, and indicator lamps for blown fuses and power, this is getting bigger and therefore more costly, for me, or any other experienced spark it would be easy to come up with what you want, but it wouldn't be cheap, as for it being a 'fun project' you'd soon get tired of trying to work out what connects to where to achieve the desired result. if you want all your switches in one central point then why not fit an unswitched socket for each machine and wire them back on radials, I.E one cable to each socket and then connect these through a separate switch for each socket, that way you've got all your switches in one place.</p></blockquote><p></p>
[QUOTE="phil d, post: 481987, member: 27126"] So from yesterdays initial idea you now want a master emergency stop, and indicator lamps for blown fuses and power, this is getting bigger and therefore more costly, for me, or any other experienced spark it would be easy to come up with what you want, but it wouldn't be cheap, as for it being a 'fun project' you'd soon get tired of trying to work out what connects to where to achieve the desired result. if you want all your switches in one central point then why not fit an unswitched socket for each machine and wire them back on radials, I.E one cable to each socket and then connect these through a separate switch for each socket, that way you've got all your switches in one place. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
