Series or Parallel, that is my question
94JDH
Jun 16, 2022
10
4
Notts
I would always use both MPPT trackers, assuming you have 2.
sorry to barge in on this thread, just wondering why its best to use both?
My installer is running 9 east panels to one inverter & 9 west panels to the other inverter (two flat roof areas - one with 12 panels/one with 6).
I was told the reason being splitting 9 (5 & 4 effectively) one of the strings would be too near the lowest input voltage of the MPPT and would be best running through one port?
Any thoughts, if you don't mind?
Hi-jacking posts causes confusion, I have given yours its own shiny new thread.
less imbalances between the panels - the panels are usual power matched before being sent out to be nigh on indentical in performance, but you do still get small differences and so a single string works at the level of the worst panel. More importantly you may have a very large bird poo, leaves or other dirt on one panel that then affects the entire set of panels. If you have 2 strings and issues like that only affects half the array, it also reduces how much energy is being forced through the bypass diodes of the affected panel - the weak point of the panels, so I prefer to minimise this where possible.
Thanks for your reply, so the Tigo Optimisers on each panel should help eliminate some of the potential problems?
