- Dec 25, 2011
- 5,470
- 80
I've been putting off draining down the central heating system until now. An odd, to my mind setup, but here goes: Oil fired boiler. Indirect cylinder. 1 3-port valve that does HW/CH or both. Odd that in after the CH take off from the 3-port I have another TWO, 2-port valves. One does the upstairs rads. The other the downstairs one. Wall stat upstairs & a second one downstairs. The upstairs rads are plumbed with each rad connected to the flow and return. BUT the downstairs CH system is an old fashioned SINGLE PIPE, 3/4" nominal bore system.
I had planned today to drain down and re-route a couple of the SINGLE PIPE system pipes as a stop gap before it all gets replaced. Went to undo the drain **** (great place BTW, behind the TV in the lounge). Had my hose all set out of the patio doors and it wouldn't budge. Tried penetrating oil after wire brushing the gloss off, Heating with a MAPP torch. Ended up shearing it off flush in the end as per photo. Then tried cutting a slot in the sheared off face to fit a plate to turn it with. Nothing works the thing is SOLID. To be honest it's not even at the lowest point on the run but would be ok for what I want to do.
Any suggestions? Thinking it'll be try and jury rig some say lengths of kitchen waste pipes out of the patio doors and just accept there's going to be a few wet carpets etc. Cheers.
