Shower switch
Raks
Oct 23, 2021
18
2
Hi there would it be okay to connect 6mm cable onto 10mm cable? The shower switch is getting moved and the cables need a joint in them, the pull cord is going to be another 1 metre away can I joint 6mm onto this?
I think you need the services of an electrician. Quoting 60A terminal block suggests this is beyond your level of competence.
Yeah I was wondering if anyone knew what I needed first thanks
It isn't a case of what you need but what would an electrician use.
Welcome to the forum. Unfortunately there is too little information in your question for anyone to give an accurate answer.  The cable sizes used for any circuit will be dependant upon the total load that the cable has to carry, The installation methods used, The type of protective device used to protect the cable, The maximum permissible earth loop impedance to comply with BS7671, (wiring regs), for the type of protective device used. Which must all be considered to ensure that in the event of a fault, you will not endanger people property or livestock. There are NO simple rules that say a shower must be 'X', 'Y' or 'Z'.  Just as saying if I have a red or blue car what size tyres must I use?
If you are unable to provide additional information, the safest solution would be, as Fleeting suggests, to get a local electrician to come and assess your exact requirements.
