Shower
mpv1961
Oct 10, 2011
4
What could be the cause of smoke coming from the top of the shower unit when it is in use, I have temporarily disabled the shower, does it mean a new shower or could it be a simple fix.
smells burning but cant see anything at all and have done a visual inspection of all the shower.
Have you taken the cover off ??? after safely isolating it and looked at the connector block ???
1/ Welcome to the forum.
2/ SMOKE!!! serious issue, most likely something had major component overheating. unlikely to be repairable!
3/ How old is the shower?
4/ Who installed it? DIY or qualified electrician?
5/ Could be faulty installation, bad poor terminations of the cables at the connector block. incorrect cable size.. (see Q3)?
6/ It could be faulty internal wiring, in which case it may be under some manufactures obligations to replace it...
7/ But if incorrectly installed (see Q4) could be no way of claiming any refunds for a new shower..
Can you post some pictures of the shower with the cover off..
(REMOVE ALL POWER FIRST!!!!!)
DO NOT under any circumstances try to re-use the shower unless the appliance and the supply cable have been properly tested with approved test equipment
:coffee
Specs
What are you trying to do ???
scare the guy ??????
one question at a time
its like chatting a up woman slow polite conversation
as appossed to .......... do you make a good breakfast !!!!!!!
SpecsWhat are you trying to do ???
Sorry! :Blushing
forgot to ask....
Thong/Briefs/Boxers???
or go commando!!! :innocent
it was fitted by qualified people but is 5+ years old, forgot to mention about 6/8 months ago it started to trip out the mcb on the odd occasion if it had been on for a while.
the smoke makes it work. once all the smoke has escaped, it will stop working.
possibly burning down the house in the process.
do not use the shower and call an electrician to repair/replace it
would a fluke 1652 test meter tell me where the problem lies if I tested the insulation and the continuity ??? and possibly the earth loop from shower terminals
Some more information may be a help mpv1961, what is the shower rating, cable size and breaker rating? If you are having to ask about what possible test results may mean using a fluke 1652 I am not convinced this would help you locate the fault. Are you an electrician or student of some sort mpv1961? I think any competent electrician would know by second nature what they can check to verify the condition of the unit. But as the others have said my money would be on you need to replace the shower unit. Welcome to the forum.
NO,
I havent yet come across any meter that will show me a fault,
it is down to the person using the test equipment to determine to relevance of the readings they obtain.
one of the first problems you will have to overcome is in finding someone competent enough to test it for you,
its not a DIY task.
