simple question with a??
bob
Mar 23, 2008
294
possibly a big answer
i want multi room audio i have seen a idea in the tinternet basically a computer acting as a music server with multiple 5.1 surround sound cards, then form that cables going to each room then to an amp after that to the speakers.
Can I make a 5.1 speaker system with individual components from maplin or rs components
the sound card in question is from maplin A80JB it says "
i wanted to check before i buy everything, but it sounds like it works in theroy i know i mentioned this but do u know where i can get a cheap amp like under 30squid coz 80squid is a lot of money coz i only need 1 or 2 input not 5 or 6:D:)
bob
it wont be 4 a few weeks coz of cash i have a brick bbq to build first
bob
so does that mean it can work with Linux coz another license 4 win XP is 2 expensive.bob
I reckon M107 can give you good advice on the hardware, also look at audio multiplexers as a distribution method, do you need to have different audio in each zone?, if so it will get a little more complex
Why do you need 5.1, this is really a movie requirement, DTS was the only marginally successful surround 5.1, but the artist catalogue is some what small, 2.0 should more than suffice for an mp3 server
4x XP licences hmmm no comment but I'm sure people find away around that small difficulty ;)
As Linux is an Open Source operating system (no licences too) you can get pretty much any thing working if you know how to code, or add .src files to Linux, a good Linux distro to use for this is http://www.kde.org/ very much suited to multimedia apps and project such as yours, also have a look at the XBox Media Centre ported to PC's Linux, Windows etc http://xbmc.org/ I have this running under KDE for movies in one room
Robojin AKA "The Rocket Scientist" :D (but not the A-Team :D :D] :) )
i wanted to check before i buy everything, but it sounds like it works in theroy i know i mentioned this but do u know where i can get a cheap amp like under 30squid coz 80squid is a lot of money coz i only need 1 or 2 input not 5 or 6:D:)bob
Try Richer Sounds http://www.richersounds.com/splashpage.php
Might need to visit your local store and haggle with the manager
how you planning controling volume in each room,only done one myself to a pad in chelsea using cat 5 cables slimline controler in each room fed sky through from a digibox into multi channel amp cant remeber the name bought from smallbrook queensway Brumagem.
i would only need 1 license for win XP i used "4" coz it was shorter than for:D
