juniorspark
- Jan 15, 2011
- 34
- 0
was asked a question today and couldnt find the correct explanation to give can someone help with a better answer than "because it does"?
if you have a circuit then live carries in the current goes through the load and returns to the supply through the neutral, however if you remove the load then you will create a dead short by connecting the live to the neutral so what is it about the load that stops this effect? given this a lot of thought and cant think of answer
