Right, how can i put this simply
NICEIC are wrong
Elecsa are wrong
Napit are wrong
Dual RCD boards, single RCD. Boards do NOT comply. In the majority of cases
There is a Reg ( i cannot be ar5ed quoting numbers, you want it, YOU find it)
CIRCUITS ARE TO BE INSTALLED TO MINIMISE INCONVENIENCE IN THE CASE OF A CIRCUIT TRIPPING
so if you fit a split RCD. Board .a...)somebody made up,the names 17 th edition or 16 th edition board........bo11ocks)
You HAVE NOT MINIMISED INNCONVENIENCE YOU HAVE AT BEST HALVED IT,
Definition of minimise means , well you go and look it up
These are MY opinions AND the opinions of other sensible folk.......the rest are wrong
Rantette finishes
Just saying
