size of cables
danny7299
Apr 6, 2008
880
Leicestershire
Does any one have a good way of identifying size of conductors...?
I know a lot of you will just do it from experience but the job I have just been on I am not to sure...
Is there any way of measuring them?
well it would give you a ball park idea wouldn;t it ...
If the conductor was straight and you know how to read a micrometer it would give you a very precise answer!
I have a micrometer - may have a play when I get home.
You could use some different sized cable lugs as Go/No Go gauges to test for fit, would only be good for circular section conductor . If you are able to power down for a visual inspection look at the cable lugs if fitted, have their seizing stamped on them usually .Thats if correct lugs have been fitted.
How about a bit of plastic or brass plate with holes drilled for the various sizes and then have it on your van keys
thats a good idea... but you would have to find right bits... also doesn't help you much if cables are live and you can not dead them.
also how would you messure a shaped conductor? hummm ?
Good question, and like you have said most do it from experiance rather than direct measurement.
If the cable is stranded the number of srands normally would indicate its size, and there are charts for identifying these.
Its very much the same for imperial sizes, which where almost all exclusively stranded.
It is quite common and perfectly acceptable to put the new metric size nearest to the old imperial on the pir providing that it is not guessed at.
Another way to determine the csa is to do a measured continuity test, however this would involve testing a cut piece minimum length of 0.5 meters.
So not very practical.
Older cables will look larger in csa than they actually are, this is because of the process of applying the insulation was not as good, or efficient as it is today.
i think the best option so far is going to be with a with a micrometer, a bit of common sense, and working out the loading size.
Rather than measuring the overall size of the cable, I measure the diameter of a strand. From this you can work out the size of the cable. I do this especially for imperial cables when changing consumer units. I've made look up table to find the ratings too.
Imperial cable ratings.pdf
  • Imperial cable ratings.pdf
    11.9 KB
