socket in space above workbench
TTbangbang
Trainee DEI
Sep 16, 2008
261
Hello Ladies and Gentlemen,
How would you fix a socket in free air above a workbench? Vertical pvc conduit and a metalclad box? ?:|
Thank you for your thoughts :)
TTbb
Use a sky hook ????? :^O :^O:^O
i would use metal conduit personally
the comercial guys will have better thoughts
if you're dangling from above the usual is jack chain and hooks .metal clad socket.
it'll need flexible cable i.e sy or yy .tywrap to the chain
From below - metal conduit & m/c box.
From above - jack chain & hituf - of some description (as noted above)
OR
a proprietary power solution such as the Vetman has suggested.
KME
Many thanks for the replies. Also great to see a piece of equipment I never knew existed :D
