Socket tester puzzle.
dave2
Apr 14, 2008
239
Co.Durham
Today's job was a freebie for my daughter.
She is wanting some extra sockets in her lounge.
I decided to use my Fluke socket tester to verify which circuit to isolate.
The tester is showing 2 green and 1 red led illuminated. Eh?
Go to the board and do global insulation tests-- 4.5M  ohms L-E, N-E and L/N-E.
I switch off all mcb's and the tester is now showing 1 red led.
Check all voltages coming in and they are ok. No voltage N-E.
It's a TT system (RA=12 ohms) and main switch is 30mA rcd.
Disconnect neutral and no led's are illuminated.
I rig a test socket direct from rcd out with earth connected to Ra and all bonding disconnected. All live and neutrals isolated
Same problem- 3 led's illuminated.
Rcd tests ok x1 and x5.
Socket tester works ok on neighbours sockets.
Your thoughts please.
I would have to guess that you didn't have 2 green and 1 red light showing.... I'm guessing that you only have 1 green and that the other is bleed through from the lit green.
So IMHO you have a L-N or L-E reverse,,, but then again I'd have proved it with a volt meter
but then again Canoey is probably right as I was looking at the SM100
Canoeboy said:
Does it not say on the tester what the LED code means ?
My one of those went mad, just tripped 30ma RCD's all the time & went in the bin.
I assumed it was all that bouncing about in my van that finally killed it off.
I do remember getting greens and a red but cannot recall the problem.
Found this though.
Have a kewtech one now & all is well.
I found a unknown fault with mine last week , i think it was left red other 2 green & it turned out to be a missing neutral.
Found this though.
thats the thing some socket testers check for more things than others
I have trouble chucking things I payed money for :C
I did however chuck a load of old test leads away that I was hoarding just in case..."just incase what ? you break a test lead and your going to fix it with a broken test lead!?"  OFFS!
just chuck it away but make sure it doesn't have one of those no throwy away symbols on it!
:slap
And my van resembles a well organised skip actually!
