Was it your choice to fit the equipment in the loft. I would never recommend this and more so with battery's. Unless you make it very ventilated. My system was put in by a company in the loft if I could turn back the clock it would not have been put in the loft. I have had 3 battery failures an inverter and controller all in summer periods. It was the heat. I now have installed a rimmed fan so all the electronics and battery have an circulated airflow .next year I intended to move them into an X gpo box which will be on an out side wall ground level. Just sharing my experience.Hi,
I am currently having a solar system installed and would appreciate any feedback as some things don't sit right with me.
Some things I've noted:
1. I think there should be isolator switches between the inverter and solar panels?
2. I wanted the fuse box with the export meter to be installed in attic next to inverter with the rest of the equipment but was told it wasn't possible due to 3m distance requirement and that's why it's outside next to grid connection to house. The Inverter is on the same wall/side of the house and directly above the outdoor meter boxes. Is this right or could it have all been installed in attic?
3. I wouldn't think running the solar input cables behind the inverter is acceptable?
I'd like to know if these installers have done a professional job?
Thanks.
