speech dialer
stringy
Oct 19, 2008
148
hi guys
ive been asked to fit a dialer onto a honeywell alarm panel, the dialer is a texecom one, customer has no manual for it.
anybody ever fitted one, ive never done one before bit unsure how they work
thanks
not to sure tbh mate, ive not seen the panel or the dialer as yet
gives me something to go on though thanks
hi guysive been asked to fit a dialer onto a honeywell alarm panel, the dialer is a texecom one, customer has no manual for it.
thanks
Have they told you which honeywell panel it is ? - is it security or fire ?
All dialers work near enough the same way. They need a 12v supply from the alarm panel. A pair of cables as the input or trigger (+ extra cores if you have a dialler such as the SD1 where different triggers can operate different messages) A tamper pair if needed and last but most important, the phone line!
The easiest way to get a trigger is to tap off the bell output
thanks for the replys lads
went round today and had a quick look, the panel is a honeywell accenta cheap looking thing with a seperate keypad.
slipshod you say the best way to get a trigger is to come off the bell output, is that + & -
then just 12v from the panel?
cheers
Hi Stringy,
AFAIK as Accenta does not have communicator connections then connect up as follows:
Alarm Panel ----------------Speech dialler
Aux + connect --- 12v
Aux - ---------- 0v
Global tamper -------- Tamp terminals
B --------- Trigger Input 3
Telephone Master Socket----Speech Dialler
Term 2 -------- R Blue/white core (telephone cable)
Term 5 -------- T White/ Blue core
This will only give you the option of one generic message to be dialled out when alarm triggers, so you want be able to send out variuos messages as to the alarm state ie intruder, Panic, Fire.
Hope this helps you out mate.
