So there's no need for the second cut out stuffed in the trunking?i took the cu cover off when taking the photos... also with the trunking lid..
the meter was moved 9 yr's ago.. the first cut out is in the living room corner all boxed in
But in any event, the DNO's problem to sort out.
At the bottom of the meter it says Property of the London Electricity Board (LEB). It also has there serial number on it & its normal for these meters to have a 240V label. The only concern any meter reader may have would be the taped side , but they are just civillians doing a low paid job and probably would not be bothered to report that.Is it, in fact, the DNOs meter? I don`t see any labelling?
Or is it the client`s / landlords own credit meter?
Something isn`t right there. 9 yrs, and no meter reader has ever flagged that! I`ve got a feeling you may find the DNO meter somewhere else?
