Hi All,
Some time ago i decided to replace the single phase motor on my shaper with a three phase one like it originally had. Soft me threw away the original control gear years ago..
Now, I would like to wire it up with stop, start, and provision for "jogging" too. Now, i know that this is not as simple as it sounds....
First off; If you do it the "simple" way with a NO/NC switch to do the jogging, you can in theory, and i have ACTUALLY SEEN THIS IN PRACTICE, a situation where if you give a quick "stab" to the jog button, there is a "race" between the switch and the contactor, as to which opens first. If the switch wins, the machine will keep running....
Now, I COULD use a selector switch to select "jog" mode, but i know that i would forget to operate it at some stage.
The "proper" way to do it, would be a contactor control relay to work the jog function, to "separate" completely the "run" and "jog" modes. However, this makes things a lot more complicated. I had an idea!!!! [Oh no! you all say!] What would happen if i used TWO contactors in parallel?? One for the running, and the other for the jogging???
Anyone see any snags...
john...
john...
