Hi there. First post. I'm a keen DIYer and like to try some of the simpler electrical tasks like moving sockets, replacing ceiling roses, etc. I've recently moved house to a 30 year old chalet bungalow and decided to replace the ceiling pendants with GU10 LED downlighters. I've done this in other homes several times before without a hitch but appear to have done something wrong this time. Perhaps someone could help?
So far I've replaced the pendants/ceiling roses in my lounge and dining room with 6 and 4 downlighters respectively. The dining room is fine but I find now that the 3 gang switch in the hall which operates the hall, stairs and light outside the front door, will only operate these lights when the lounge lights are switched on. Furthermore, switching the lounge lights off will switch off the hall, stairs or front door light off as well if they are on. These lights cannot be switched on again until the lounge lights are switched back on!
Can anyone make any suggestions or should I just swallow my pride and ring a spark!
Cheers,
Rob
Cheers,
Rob
