Taking a spur of shower to connect spa bath
Status
Not open for further replies.
Scott 4098
Dec 3, 2021
Good evening,
Looking for some advice,
I'm fitting a spa bath and need a power supply for it,
Q) Is it possible to take a spur from the shower supply to power the bath?
I'm thinking this might be ok as only one of them would be in use at anyone time, or would I need to run a completely new supply from the consumer unit down stairs.
Your advice would be greatly appreciated, many thanks
Scott
I would suggest your first point of reference should be the manufactures installation instructions for both the spa and the shower...
See what guidance they recommend....?
I doubt they would anything like what you are proposing...
Unless you are including some switching device/contactor to prevent them both being energised at the same time..
I also doubt I would be using a single supply for both..
Unless of course the shower is a mixer shower & the supply is just a pump..?
:coffee
Type/rating of existing protective device.
Ib of existing shower circuit.
HP of shower bath motor.
We need much more info.
Status
