Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Tempory Power Supply
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Marvo" data-source="post: 343622" data-attributes="member: 20838"><p>All jokes aside absolutely definitely don't do it. Unfortunately it's the DNO guys that are also likely to get killed, your dangerously wired generator can make cabling live all the way back to the high voltage distribution network, the risk to life isn't just in your premises so you don't have the right to even consider it as an option.</p></blockquote><p></p>
[QUOTE="Marvo, post: 343622, member: 20838"] All jokes aside absolutely definitely don't do it. Unfortunately it's the DNO guys that are also likely to get killed, your dangerously wired generator can make cabling live all the way back to the high voltage distribution network, the risk to life isn't just in your premises so you don't have the right to even consider it as an option. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
