Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Tessla Powerwall 2 and offpeak economy 7/10
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="binky" data-source="post: 524731" data-attributes="member: 490"><p>batteries are better on there own cct connected to your fuse board. If your board is really old it would be recommended to have it inspected and your whole house tested - think of it as an MoT for your electrics. If you are installing a new cct, then that cct needs to be 'up to date'. Thee are lots of battery systems, you would be looking for an AC set up - ie direct connected to the grid without solar panels. Many now advertise 'octopuss compatible' for smart metering connections, which allows Octopuss to control the battery in line with cheaper off peak metering by the half hour. I've not had time to read up on such things, so can't comment on how financially beneficial it would be. But it certainly sounds interesting.</p></blockquote><p></p>
[QUOTE="binky, post: 524731, member: 490"] batteries are better on there own cct connected to your fuse board. If your board is really old it would be recommended to have it inspected and your whole house tested - think of it as an MoT for your electrics. If you are installing a new cct, then that cct needs to be 'up to date'. Thee are lots of battery systems, you would be looking for an AC set up - ie direct connected to the grid without solar panels. Many now advertise 'octopuss compatible' for smart metering connections, which allows Octopuss to control the battery in line with cheaper off peak metering by the half hour. I've not had time to read up on such things, so can't comment on how financially beneficial it would be. But it certainly sounds interesting. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
