Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrical Inspection & Testing Forum
Test Certificate Form Filling Question
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Sharpend" data-source="post: 371629" data-attributes="member: 17152"><p>On the test sheet I put the RCD on its own line and fill in the relevant details for the RCD, such as disconnect time, mA rating and trip time x1 &amp; x5, etc</p><p></p><p>I then fill in each line for each circuit and on a split board put the 2nd RCD on its own line followed by the relevant circuits below.</p><p></p><p>I find this way it clearly denotes the RCD and it's details/test results, similarly the circuits are clearly defined with details and results.</p></blockquote><p></p>
[QUOTE="Sharpend, post: 371629, member: 17152"] On the test sheet I put the RCD on its own line and fill in the relevant details for the RCD, such as disconnect time, mA rating and trip time x1 & x5, etc I then fill in each line for each circuit and on a split board put the 2nd RCD on its own line followed by the relevant circuits below. I find this way it clearly denotes the RCD and it's details/test results, similarly the circuits are clearly defined with details and results. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
