sparky999
- Mar 24, 2008
- 405
- 0
Hi Guys
Im just starting to fill out my own test sheets at work. I just wanted some advise on some points on the sheets.
First of all on the main switch Characteristics it asks for the bs en number for the main switch it says 100A and AC22A is this the number or just a model number?
Also With the circuit description its has reference methods for how it has been wired. For the SWA we have put in goes into a duct and buried under the floor. I had a look in the regs book 16th edition and all i could fine was method 12 and 13 is this the right one for this.
Also on the circuit results, the board we are using is a main switch and rcd 7 x 7 is it ok to use just 7 lines for the main switch and 7 spaces for the rcd on the same sheet.
Cheers;\
Cheers;\
