http://i886.photobucket.com/albums/ac68/ste5lfc/78fdd6cf.jpg
3 phase board run off the bottom left breaker kept dropping a phase ...
none of the terminations had been tightened up at all , factory is 18 months old , not one cert for any of the work, no key switches on any of the emergency lighting , no circuit labeling on anything what so ever ..
bad day explode
Another pic from the same Factory
main lighting switch bank , 4 feeds in (2.5mm) off different phases from local 3 phase board , 4 x 2.5 sw L&N out and someone has also took some 2.5 flex out via single switch to some 6 ft flows .... 9 cables ....... rammed in , no sign of letting anyone know that the switch bank contained 415v
http://i886.photobucket.com/albums/ac68/ste5lfc/965692a1.jpg
bad day explode
