i also thought this, i turn the hot water on only and turn the thermostat right down and it should cut off the boiler, not all go low enough though although honeywell ones do
---------- AUTO MERGE Post added at 18:50 ---------- Previous post was at 18:49 ----------
if you want to test temperature, im sure you could by some kind of device
