You need to think this one through properly, it may start as a hairdressing salon but how long before they add a few sunbeds or something else? Also if the supply was 3 phase before then making it potentially a high load single phase you may severely imbalance the load on the main supply to the hotel. With 3 phase there is more scope for expansion later, think of it as future proofing the install.
Last year we did some work on a church, the sub board was single phase and way too small for what they were adding, the main contractor had been let down by the original spark, after the quote had been done and with what had been spec'd it just wasn't going to happen. Anyway by making the new board 3 phase, we were still able to utilise the new cable that had been bought (6mm swa) but we were able to run everything that was required.
It was either a case of the other spark hadn't a clue or he'd really messed up his calculations, either way the new load was not going on a 6mm single phase supply.
Personally I think you'd be nuts to sacrifice a perfectly good 3 phase in favour of a single phase supply.
