towel radiators for bathrooms
tom1
Distinguished Member
Aug 7, 2009
2,330
whats best to connect to, outside and inside zone 2
do people put a switch in bathroom?
If I can drill a hole in the wall in-line with the flex of the towel rail pass the flex through the hole and put a switch fuse spur over it .failing that a pull switch down to a flex outlet plate in the bathroom
u dont always get a lot of flex with the elements, have u used flex outlet plates fed from fcu outside the room
yes you can but looks neater with cable going through small hole in wall straight into spur
most towel rails come with at least a meter of flex which is more than enough
